Root Two simple questions
If you chose "update now" the phone will attempt to update, but will then fail because of the custom recovery.
also the wallpaper thing wont mess up the phone :)
More questions, haha.
Is there any way to make it stop asking me to update?
There is a clock widget that needs to be flashed in. After I flash it in, how do I get it to come up?
Thanks again. I appreciate it.
If you hit update now, your recovery will block the install and it'll stop asking you to update. As for the clock just long press on your homescreen and select insert widget. You should see the clock.
That's what I thought too, about the clock, but it's not in there. Maybe it just doesn't work on Allys. In flashed it in twice while in recovery to get it, but I still can't find it anywhere.
