MikeHoncho
If you guys are getting that error then your bootloader is locked. You should be able to unlock the bootloader in Developer Options
That is 100% how its supposed to look. If you're trying to install CM though you can't use the download manager. You need to flash it manually like in the OP.Good evening,
I used the link provided in the OP and I am looking to install TWRP using the TWRP Manager. After choosing the device name (c50) and recovery version (twrp-2.8.7.0-c50.img), I click install recovery. Once the download is complete, a message pops up asking me to verify that the partition listed below is the correct one for my device "/dev/block/bootdevice/by-name/recovery "
Is that how it is supposed to look or should there be other values for "bootdevice" or "by-name"?
Thank you in advance.
I meant that using the TWRP download manager is the wrong version if you want to flash CM.@KarmaCatLive , thank you for the response. For now I am just going to make a back up and do some more reading to familiarize myself with the process of flashing ROMs, files and performing recoveries should anything happen. I do understand CM needs to be flashed manually. Thanks again.
Tried dd and flashify method both failed just keeps booting back rom
I have metro pcs model number lgms345 rev. 1.0 with software version ms34510d,.....
Stumped.I do get a secure booting error, error 1003 at LG boot screen now though.
Unlocking bootloader:
Now the bootloader is unlocked.
- Launch the Settings Application
- Scroll Down and Tap on About Phone(or About Device)
- Locate the Build Number Section
- Tap on the Build Number Option 7 Times
- Go Back to the Main Settings Page
- Scroll Down and Tap on Developer Options
- Enable USB Debugging mode.
- Look for the ‘OEM Unlock’ Option in the Developer Mode Section (tap and check the box)
