Solution for bootlooping to TWRP after OTA update
I've got 2 simple commands to ease everyone's troubled minds. The overwhelming sense of accomplishment you'll get knowing you can use your device again. Take a step back and appreciate this moment. All joking aside, here you go.
You now have two choices. Follow the directions below or download the zip and flash in TWRP.
http://androidforums.com/resources/twrp-bootloop-fix-zip.214/ & please leave a review there.
Start up Terminal Emulator from TWRP.
Hit enter (return)...wait, takes a few seconds
Now input this
Hit enter (return)...wait again.
When its complete, reboot.
_____
Tested and verified numerous times by myself before release.
Also as a note, you may have to reactivate your device before using data or the phone.
______
Disclaimer:
I will not be responsible for damages that occur to your device due to using the above TWRP commands.
_____
If this has helped please press LIKE, a pat on the back is always nice!
- Since its showing a file browser, hit the select button - bottom right, now you can enter command lines.
- Enter commands EXACTLY as shown (please read disclaimer below).
Code:
dd if=/dev/zero of=/dev/block/platform/msm_sdcc.1/by-name/fota
Now input this
Code:
dd if=/dev/zero of=/dev/block/platform/msm_sdcc.1/by-name/misc
_____
______
Disclaimer:
_____
