Are you using a 6.0.X version of Clockwork Touch? I'm still using 5.8 on my GNex because of all the fears of bugs, so the only one for the N7 I saw was version 6+ and was a bit leery about it. Thanks for your help!
+1 using it on my N7 and works great.6.x CWM has been fine for a while - a few early bugs, but they were fixed fast and I've been running it on both for a couple of weeks at least now. Tiny and FAST nandroids. Try it.
So I just flashed TWRP on my N7 and it fails if I try and just wipe data. If I do a factory reset it works fine it seems. Is this normal behavior? I'm running 2.2.1 now with no installation problems. Thanks for the help.
Personally, I had quite a lot of problems with TWRP on my N7 (it works just fine on my Gnex) and had to revert to Clockwork. You could try giving it a shot, or try reflashing TWRP through Goo.manager.
