slimchance
It seems that TWRP Recovery is now 'official' for the Wildfire S (GSM version) - see TeamWin Projects - TWRP 2.2 | TeamWin
It can be installed through GooManager.
WoefulDerelict (the developer) says on XDA:
"Currently there is NO custom recovery that will properly support the fidgety new revision to the Wildfire S. If the official 5.0.2.8 results in a black screen on your device then you will not find any CyanogenMod kernel based software that will work on your phone. All CM GB based projects will result in a black screen and all CM ICS/JB projects will result in your device halting at the initial splash: the green HTC on a white background."
