I haven't ran debian stable since woody and once briefly with sarge when it first came out to test it
I have stuck with debian sid (unstable) since about 1997
I would try Debian if it had some ability to easily install proprietary drivers
That depends on what it is, the most common would be video card, pretty easy
nvidia
Code:
apt-get update && apt-get install nvidia-glx nvidia-settings
amd/ati
Code:
apt-get update && apt-get install fglrx glx-alternative-fglrx fglrx-control libgl1-fglrx-glx
depending on what you want or need, packages are easy to install on debian, just like the proprietary drivers above
ubuntu for installing packages uses synaptic to install apps, synaptic is just a frontend wrapper to apt.
have Ubuntu patch Debain's unstable packages
I really hope your kidding on that, that will never happen, and would severely break just about everything and would ruin debian
ubuntu is not debian binary compatible, not even close, what ubuntu does to debian packages disgusts *most debian people/users/package managers/devs, etc
What ubuntu does is take a collection of packages from debian, from both the stable and unstable repos, at a particular time, than freeze that snapshot and try to make a reliable distribution out of that snapshot.
Then they come back 6 months later and do it again, but, during that 6 months, debian unstable had evolved, and evolved alot, dependencies, libs, etc change, occasionally things are just plain broken.
In debian unstable, those breaks are eventually resolved, actually within 24-48 hours but ubuntu waits another 6 months before grabbing another snapshot of the repositories and the circle continues
This is why ubuntu breaks alot
Just don't install a ubuntu.deb on a debian system unless you can debianze (convert it to a debian.deb) it or are willing to fix your system, dependencies, libs, sym links, etc, after your next dist-upgrade
I won't get into it anymore here, I will be nice
debian sid updates 4 times a day (dist-upgrade)
I run 3 systems
lfs (linux from scratch)
aptosid
siduction
all 100 percent debian sid and built from scratch from the ground up by me (using pyfll) except for kernel which i haven't done in while and don't need to
system using at the moment
Code:
piper@x1:~$ inxi -F
System: Host: x1 Kernel: 3.7-1.towo-siduction-amd64 x86_64 (64 bit)
Desktop: KDE 4.8.4 Distro: pipers-reloaded-siduction 12.2.0 Riders on the Storm - kde - (201212281949)
Machine: Mobo: Gigabyte model: GA-970A-UD3 version: x.x Bios: Award version: F7 date: 10/22/2012
CPU: Hexa core AMD FX-6300 Six-Core (-MCP-) cache: 12288 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm)
Clock Speeds: 1: 1400.00 MHz 2: 3500.00 MHz 3: 1400.00 MHz 4: 3500.00 MHz 5: 1400.00 MHz 6: 1400.00 MHz
Graphics: Card: NVIDIA GF106 [GeForce GTS 450] X.Org: 1.12.4 driver: nvidia Resolution: 1920x1200@60.0hz
GLX Renderer: GeForce GTS 450/PCIe/SSE2 GLX Version: 4.2.0 NVIDIA 310.70
Audio: Card-1: NVIDIA GF106 High Definition Audio Controller driver: snd_hda_intel
Card-2: Advanced Micro Devices [AMD] nee ATI SBx00 Azalia (Intel HDA) driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture ver: k3.7-1.towo-siduction-amd64
Network: Card: Realtek RTL8111/8168B PCI Express Gigabit Ethernet controller driver: r8169
IF: eth0 state: up speed: 100 Mbps duplex: full mac: 90:2b:34:a5:99:2d
Drives: HDD Total Size: 2320.5GB (77.1% used) 1: id: /dev/sdb model: ST31000528AS size: 1000.2GB
2: id: /dev/sdc model: ST31000528AS size: 1000.2GB 3: id: /dev/sda model: ST3320620AS size: 320.1GB
Partition: ID: / size: 187G used: 19G (11%) fs: reiserfs ID: swap-1 size: 1.07GB used: 0.00GB (0%) fs: swap
Sensors: System Temperatures: cpu: 16.4C mobo: N/A gpu: 32C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 192 Uptime: 5:10 Memory: 1030.9/7973.5MB Client: Shell (bash) inxi: 1.8.24
