M MCJ Lurker Jan 27, 2012 #1 Hi folks. My HD on my PC had to be reformatted and therefore I lost all my Outlook contacts. Is there any way to PUSH the contacts from the phone TO the PC? I installed HTC sync but it seems to only pull from Outlook. Any help is appreciated. Thx, MCJ
C chrstdvd Android Enthusiast Jan 27, 2012 #2 I do not use Outlook, but if you sync all your contacts with Google from the phone you should be able to import them into Outlook from Google.
