Well, it seems my flawless Triumph is flawless no more. It won't charge unless you push the connector in really hard and twist it a few angles until it starts charging. I tried multiple cables (including the Moto one) and made no difference
I got it charging now, I am going to get it fully charged, pull the battery, boot into recovery and wipe the battery stats, and see if that helps, but if not, it's replacement time.
When you request a warranty replacement from VM, do you have to send the phone back first, or so you have time to send it back after you get the replacement? I ask because I cannot use a Triumph with a Truly screen, they cause my eye strain headaches, I need one with a Toshiba screen, and if I send in my device and get a Truly screened one back I'll have no phone to use.
. CM roms will turn the light green at 90%, but on stock it is green at 100%.
