Root Uh Oh
red2444
Just got my epic and rooted it. Anyway i tried to flash syndicate rom and now my phone wont go past the first samsung screen. im pretty new to this but am willing to try odin however i cant find a good link to download it. Anyone got any advice. links and instructions would be great lol
Check the stickies at the top of the forum if you haven't already.
Did you wipe 3 items (each 3 times)? Which version of clockwork are you using?
I'm having a very similar problem to this. Originally, my problem was exactly the same, but now it seems to have evolved. I tried Odin, and it says that it completed successfully, however my phone only boots into Clockworkmod recovery. Even after flashing and not using the recovery hotkeys, all I see is Clockworkmod. Has anyone seen this before? I've tried just about everything I know how to do.
Maybe make sure you've got the correct files put into odin. And that you followed the steps exactly :p
I used odin and it worked great. i think the problem was my files were not being converted into ext 4 and then my rom simply wouldnt start up. Now im running syndicate with emotionless beast. I love my new epic :D
