Uh oh.......
C
compulady5
Guest
*Update* See post #6
I've got an intermittent screen flicker with horizontal lines when I hit that power button to wake the Triumph from standby.
Unless this is a major issue, I can live with it, otherwise....... Any others?
PS I'm griping over K9 mail!!! UGH! All of a sudden I can not send mail and on top of that, syncing is all screwed up! I won't even get into the chop job mybackup pro did to my gmail contacts. UGH!!!!!!!!!!!!!!!!!!!!!
Thank you, I almost feel better.
Take it back,seen other people report the same issue,don't settle for subpar.. you spend the money... get what you paid for.
wonder if it only does it with a live wallpaper?
Oops, I meant "Nope"...
Live wallpaper, still wallpaper, doesn't matter.
Screenlock prog doesn't fix it either.
Next try-- factory reset.
Edit:
After performing a factory reset, the flicker not only continued, but my screen went white. No, it wasn't consistant, but it was enough to where I was going to return it because when it went white, it stayed that way. Anyone else?
