Root Uhoh...Need Help Please :) Fresh .5.3
zhens
So I completed step 2 of root today and decided to flash Fresh .5.3
Wiped data, but forgot to wipe SD card. Began to boot loop so I read that I would need to partition the SD card. I tried to Flash back to Fresh .2 in order to backup my SD card and began to boot loop there too.
So I go into recovery and partition (0,0)
I'm still boot looping Fresh .2 and I can't flash anything else (read: my backup) because I wiped the SD card.
Help would be greatly appreciated :)
Did you wipe dalvik cache before you flashed the new Rom? And was your SD card partitioned prior to flashing the new Rom also? Unless if you ran a2sd with a different Rom, I don't see why you would need to wipe the SD ext. Try wiping data and dalvik cache and then reflashing and see if that will get you out of the boot loop.
