Root UI Mods For Micromax A52/Symphony W5
Sakib
Hello !
Now many of you Guys Have the Micromax A52/Symphony W5 , Which does not have any Custom ROMs or Other MODS ! :/
So i decided to Make one myself !
*I WILL NOT BE RESPONSIBLE IF YOU TURN YOUR PHONE INTO A BRICK, OR IF IT GOES BOOTLOOPING*
Requirements*
*A Phone
*CWM Recovery installed !
MODs,
1.Status Bar ICS Battery ,
2.Transparent Status Bar Background
3.ICS Status Icons ,
4.ICS 4.0 UI translations
5.Ubuntu Font
Many More ..... :smokingsomb:
**First make sure to make a backup of your Current ROM from the CWM Recovery**
Steps to Install:
1.Download This https://www.dropbox.com/s/xvypqyxdaxmiwuy/UI_MODS_For_W5@gameR.zip
2.Copy it to the SD/
3.Power Off phone and Go to the CWM recovery ,
4.Install zip from SD card
5.Choose Zip from SD
6.Select the Zip you downloaded
7.Wait for it to be done and Finally Reboot the Phone !
And You are Done !
hit The Thanks Button if You Like My Work !! :)
