My UK bought DHD will not upgrade via the usual About phone>System software updates route, I just get the spinning logo for an unbelievable length of time and eventually my patience runs out or I need to do something before anything happens. It's meant to be unlocked to any network and I'm using the O2 sim which it was supplied with. Took it into the Carphone Whorehouse today and they said to try downloading from HTC.com while plugged into the USB cable but I can't see an option for that on the site? Failing that they said to send it away but that's $$ I don't need/want to spend and I'd lose app settings etc.
Any ideas how to fix it without doing an insurance job and getting a Sensation?
Software Info
2.2.1
baseband 12.28e.60.140fU_26.04.02.17_M2
kernel 2.6.32.21-g3d0aaff
build 1.72.405.3 CL296490
bowser 3.1
Software Info
2.2.1
bowser 3.1
