Help UK Mains and Link2SD 2nd Partition prob
karlx
Hi,
I was wondering if anyone could point me in the right direction to get a suitable uk mains adaptor, maybe off ebay. the pin on mine has somehow become bent, altho it still works.
I have a samsung charger that fits (atadd10ube) not sure if its suitable o not tried it yet.
input 100-240v -
50-60hz 0.15A
output 5.0v --- 0.35A
the other thing is using Link2sd
I have a 16gb with and 8gb ext tf card.
when I run the app, it informs me "Second Partition Not Found, The second partition has not been found on your SD card. Make sure you have two partitions on your SD card and both are Primary"
Whats that about?
many thanks everyone
Karl
Hi,
input 100-240v -
50-60hz 0.15A
Whats that about?
Karl
Your existing samsung charger cannot supply enough current for the tablet, the likelyhood is it will get hot and eventually fail. The specs you are looking for are 5 volts @ 3Amps and whatever mains in voltage your country uses (110 or 220/240). The output plug is 2.5mm o/d and 0.7mm id centre positive. I believe chinagrabber sell official replacement power supplies.
It sounds like the second partition (if there is one)on your tf card is corrupt or it is an extended partition, not a primary one. If you follow the instructions here [App] Link2SD - xda-developers you should be able to fix this problem.
Thanks dart16.
Something told me you'd be the first with a solution.
im in the UK. so will look into that adaptor
I have a mac, hopefully I can find something like mini tool for it. or maybe use a friends pc.
many thanks again
Karl
Hi Karl,
There only seems to be the one guy on eBay selling them at the moment, cablesat, and he has them for
