Its only Saturday. If its not out by Monday we know something is up.No update yet?
Im fixing a few visual cues... May b early in the week... Its coming along nicely thoughIts only Saturday. If its not out by Monday we know something is up.
Next update.just saw these three roms today, my question is, that the images shown are they actaully released or are they in the next update?
Op shows current rom all after are next releasejust saw these three roms today, my question is, that the images shown are they actaully released or are they in the next update?
sorry for the dumb question what exactly op?Op shows current rom all after are next release![]()
Original post... The first post in the treadsorry for the dumb question what exactly op?
Yes only first version i am near ready to release my next update which had alot of changes cosmetically over the first as well as the ability to select ur statusbar battery iconohhhhhh, so there isnt any update right, only the first version?
You can change the battery icon in some xposed apps also if you can't wait.Yes only first version i am near ready to release my next update which had alot of changes cosmetically over the first as well as the ability to select ur statusbar battery icon![]()
Yes. But you will need to do a factory reset on his ROM. The ROM will take a good but longer to boot than the G3 ROM because it is not optimized like the G3 ROM so don't get stressed when it takes 2 minutes to boot.when flashing this rom, do you use the same steps as the g3 rom?
Yes because you are less likely to get a brick. He made lots of changes to core functions. He changed lots of apps and stuff. I only updated apps and ported them from other LG ROMs.wait, you have to factory reset the phone?
1. Press factory reset in TWRP.so how would i do that, just go into back up and reset and press Factory data reset, or go into to TWRP
Yes you can restore it. No it does not have flashify. But there are options in the power menu.can i still restore my back up? and does it have flashify to boot in to recover?
Good idea. I always try every ROM before I use it as a daily driver.ok i am gonna try his
Same thing.factory reset is the same as WIPE in TWRP right? or do i have the wrong picture
