Root UltaLolli ROM for LG Ultimate 2
Every time I change the lock screen wallpaper it goes back to the Tracfone beach wallpaper. This happens at every reboot. It is getting annoying.
As far as lockscreen issue i will look into it thanks for pointing this out... V2.0 is still affected will look at for next release
I just tried Version 2.0
Positives
1. amazing new notification panel
2. Date and Time customization
3. Lollipop like setting
4. List view animations
Negative
1. Qslide (that was the only good thing about LG's UI)
2. In recent apps, i'd like to see the boxes a bit small and with their names
3. I know this is alot to ask, but in the next release how about the actual lolipop animation for the recent apps menu
Overall i enjoyed the experience, as it was close to lolipop
Maybe you can remove the Tracfone wallpapers next time and add Lollipop ones for the lockscreen. Overall the ROM looks and feels like AOSP Lollipop for sure. Debloated and fast! [emoji4]
Positives
Negative
V1.0 had listview as well and as far as ur cons i replaced all qslide apps and will not b adding bk... Recents panel is stuck as it is due to lg code and i may add app name bk if more ppl want... Any other suggestions?? Im going to theme contacts, dialer and gallery for next release
Glad u like it :) im actually looking into replacing lg lockscreen with aosp...
That is even better, I'd say go for the aosp lockscreen. You should also considering adding the new Google Photos app and Google Plus.
MY PHONE BRICKED! I flashed it and now it won't go past the LG Android screen where the home button flashes, and I can't boot into recovery! Help!
Do a factory reset:
  • Press and hold "Volume Down" and "Power" at the same time
  • When the LG logo appears, release the "Power" key and then press and hold it again
  • When the "Factory data reset" screen appears, release all hardware buttons
  • Use the "Volume" rocker to select "Yes", and press "Power" to confirm
  • Your smartphone will factory reset and reboot in normal mode
Umm what ROM did you flash? Or to be more specific what did you do to it? You will need a replacement phone.
I flashed this one and it booted at first and everything kept FC so i turned it off and now and now it won't go past the LG logo. I tried all the standard methods to boot into recovery (Power, Volume) and nothing happened.
Ussaly a reset fixes this stuff.
rcunningham explained how to:
Do a factory reset:
Do a factory reset:
Still nothing. I am currently in a chat trying to get a replacement. Wish me luck :/
