edodson84
Android Expert
I recommend cwm as u can access recovery from power offTWRP.
it wil factory reset and stop then all u do is from a pc "adb reboot recovery"Follow along with the video below to see how to install our site as a web app on your home screen.
it wil factory reset and stop then all u do is from a pc "adb reboot recovery"i like the UI of TWRP more, this is also why i generaly let more people try a the ROM, that way i know if it is safe to use or not lol, that's why havent tried cyan11 yet, hope someone tries itI recommend cwm as u can access recovery from power offit wil factory reset and stop then all u do is from a pc "adb reboot recovery"
My rom is 100% safe as i test flashed on 2 devices b4 release ur issue sounds like user error...i like the UI of TWRP more, this is also why i generaly let more people try a the ROM, that way i know if it is safe to use or not lol, that's why havent tried cyan11 yet, hope someone tries it
oh sorry, i worded that wrong, i tried your rom already its pretty good, i was talking about cyan11 being safe, sorry for the confusionsMy rom is 100% safe as i test flashed on 2 devices b4 release ur issue sounds like user error...
Yeah sorry got u confused with the bad flash guy lol and yeah i didnt try it dont want to get a brick as the cm rom is for the l70 not l41 but it may work as they almost the same deviceoh sorry, i worded that wrong, i tried your rom already its pretty good, i was talking about cyan11 being safe, sorry for the confusions
It worked on the Realm and I ported it and I did not just copy it. I fixed the Touchscreen bug.Yeah sorry got u confused with the bad flash guy lol and yeah i didnt try it dont want to get a brick as the cm rom is for the l70 not l41 but it may work as they almost the same device
How do u know if u nvr tested it???It worked on the Realm and I ported it and I did not just copy it. I fixed the Touchscreen bug.
CM worked on a guys realm but the touchscreen failed so he had to go back to stock. He used the L70 CM. I fixed the touchscreen by replacing the touch files.How do u know if u nvr tested it???
Ok i may try on my old phone when i get timeCM worked on a guys realm but the touchscreen failed so he had to go back to stock. He used the L70 CM. I fixed the touchscreen by replacing the touch files.
YesIs ur old phone an ultimate 2
You would have to rework the ROMAny idea where I can delete the built in Tracfone wallpapers?
Did u try cm11Ok i may try on my old phone when i get time
Looks Kit-Katy.No but i did manage this
Yeah its aosp 4.4.4 lockscreen themed a bitLooks Kit-Katy.
No it does not but its better than lg only issue is if u pick knock code it will perma lock u out of the device lol gonna removed the option if i canThat's a nice aosp, does it have notification cards
will it do that in the current verision of ulta loli too?No it does not but its better than lg only issue is if u pick knock code it will perma lock u out of the device lol gonna removed the option if i can
Yeswill it do that in the current verision of ulta loli too?
V2.0 has the lg lockscreen so all functions workwill it do that in the current verision of ulta loli too?
