UltimateRoxxs
Cool, what's in the next release, will it be next month?
Mainly just lockscreen and im gonna theme a few more appsCool, what's in the next release, will it be next month?
I will make a flashable for those who want it but myself i prefer the aosp stylingBut the gallery is better than the old one
The lockscreen is looking great with the widget on there.![]()
Add ability to add widgets and fully centered lock handle![]()
U can different widgets as well:The lockscreen is looking great with the widget on there.
The rom has exposed by default... Problem with most of the modules is lg calls their own resources instead of aosp... Plus hard coding the theming is better on resources (eg: phone runs faster)could you see if you could incorporate this somehow?
http://mgeeky.com/completely-theme-any-rooted-android-like-lollipop-with-xposed/
Lg calls their own quick settings... I may b able too i did it to my lawe rom i made for the zte awe which is a 4.1.2 jb deviceI know its exposed by default, but can you get the notification bar to look like how it does in the link
You can use Color Status Bar if you want those notification bars.I know its exposed by default, but can you get the notification bar to look like how it does in the link
I tried color status bar, its not a stock experiences, if you could get the notification bar from the link that would be greatYou can use Color Status Bar if you want those notification bars.
Try the Xposed module called GravityBox [KK]. Turn on quick settings and you should be set. GravityBox has many more features as well. It is by far my favorite Xposed module.I tried color status bar, its not a stock experiences, if you could get the notification bar from the link that would be great
You wont brick by installing that. I did it on the stock ROM and the G3 ROM but I am not sure if it will work on the UltaLolli ROM.In the xposed app on my phone it says that it needs to be updated but I don't want to brick my phone![]()
Ur fine i didnt have xposed active until u install the framework...In the xposed app on my phone it says that it needs to be updated but I don't want to brick my phone![]()
Nope u will b okSo if I press install it won't brick
