can somwone convert this to install without a recovery?
http://forum.xda-developers.com/showthread.php?t=1908269
This is an awesome addition, thank you very much for the work. Its a shame that a large majority of the tweaks I had already done freehand.
I saw the apps and mods section though and wanted to cry, anyway possible to install the bravia mod without recovery? I know it has a high chance for a brick, but that's one mod i'd love to have.
Wifi Connect Speed
3G Signal & Speed
Internal Sd Card Tweak
External SD Card Tweak
Battery Savings
Camera Quality Tweaks
JPG Images Quality
Dialing-Time Tweak
Wifi Connect Speed
3G Signal & Speed
Battery Savings
JPG Images Quality
Dialing-Time Tweak
Battery savings = 3%/hour with rigorous use.
The beats audio isn't beats sadly, download it. The file comes up as the bravia zip.
Dont use anything from Enable/Disable functions will cause you to go soft brick to recover just back up your build.prop and adb push to device and bam! Working Motiong again no unbrick method
some one test the bravia audio plllleeeaaasseeee
Thanks! Are there any others that we shouldn't touch that'll brick our motions??
i am running everything except the enable/Disable functions and the Apps & Mods..
i have the following UNCHECKED
Disable Vsync
Disable I/O Stats
Move Dalvik-Cache to /cache
Bind Mount Dalvik -Cache
EXt4 File System Tweaks
and that's it...everything else i have checked and/or applied...and my phone is running smoother...not by leaps and bounds..but it is smoother...
