Un-check limit mobile data usage....
Devendra95
Hi i am curious if i un check the box that says "limit mobile data usage" will background data be enabled? will this eat up more battery ? if i have the box checked, some apps won't work. i have unlimited data.
I don't think its going to effect anything, its just a setting that does not let you go over the limit.
Thanks for the reply. When I individually check boxes for apps to restrict background data I get a message saying "restricting background data is possible only when you've set a mobile data limit" what does that mean ?
It doesnt eat up battery life. All that means is it wont sync stuff in the background, like check for emails or app updates, etc or news updates if you have a app for that, you know things like that.
