tamaramarrero Member Oct 13, 2010 #1 I have to send it back to the store and I need to UN ROOT it. Someone please help? I need to send it back ASAP. Thanks in advance.
U uniquenameEVO Android Enthusiast Oct 13, 2010 #2 What method did you use to root it? It could be as simple as flashing an RUU to it.
tamaramarrero Member Oct 13, 2010 #4 uniquenameEVO said: What method did you use to root it? It could be as simple as flashing an RUU to it. Click to expand... Does it matter? I mean I googled it and there was one where you flashed it's for 2.2. Can I update the EVO after I unroot it?
YaBoiD Android Enthusiast Oct 13, 2010 #5 Check out section 8 of the first post. http://androidforums.com/evo-4g-all-things-root/194918-rooting-dummies-extras.html
U uniquenameEVO Android Enthusiast Oct 13, 2010 #6 tamaramarrero said: Does it matter? Click to expand... It does if you used unrevoked forever. Other than that, I don't think it does.
