I'm pretty sure you just have to install the stock ROM that you download from HTC. At least that seemed to work for me. I had to root again after that.
Just a friendly reminder in order for a RUU to work you first have to downgrade your phone. If the RUU you are trying to run is below the firmware you currently are running (which if you are rooted it is) then you need to use the Ace hack kit to get back to root. Very simple process, it does all the work for you so nothing to worry about if you don't consider yourself too technical. xda-developers - View Single Post - [TOOL] Advanced Ace Hack Kit (UPDATED 19-09-2011) Just download the zip file and follow the manual for instructions. Any questions, just ask.
