Help unable to access system?
jay66
Tried to resrtore factory settings but it wouldnt work and all the photos and files were still there, 3 said might need flashing as virus
anyway I tried a few times more and eventually hard reset worked and back to normal, only problem is when it is reseting I get an error about not being able to access file, is this a virus or is it okay?
Coping media files...
Successfully copied media files.
# MANUAL MODE #
-- Updating application...
Successfully updated application.
-- Appling Multi-CSC...
Installing Multi-CSC
Can't access to '/system/csc/H3G/system/'.
Successfully applied multi-CSC.
Is the phone working? Did you do the factory reset from settings or the recovery menu?
If you Google Can't access to '/system/csc/H3G/system/ it throws up several links mostly to people with the same problem :( A couple of links suggest that a factory reset does solve it. You could try another. Go into Recovery mode (Power,Home and Volume up button) and do a data/factory reset.
If it's working OK however, you might leave well alone.
