About 6 months ago I was trying to change my ROM (done it many times using clockword Mod & Nandroid) when I accidentally used a ROM designed for HERO CDMA. It half installed and I'm now left with a very sluggish error ridden phone. To make it easier to show the problems, I'll bullet them...
It shows as rooted, but then revokes privileges when it feels like, so I can't actually install anything through ROM MANAGER.
WI-FI doesn't work.
Anything to do with network settings causes an error, so changes can't be made.
HTC SYNC does not find it when connected via USB.
USB connection does not allow access to SD card.
trying to install an RUU does not find the phone
Starting into HBOOT i get:
SD checking...
Loading...[HERODIAG.zip]
No Image!
Loading...[HERODIA3.nbh]
No Image!
Loading...[HERODIA2.nbh]
No Image!
Loading...[HERODIAG.nbh]
No Image!
Loading...[HEROIMG.zip]
No Image!
Loading...[HEROIMG.nbh]
No Image!
Suppose it helps if I tell everyone what software it's currently running.....
According to the 'About Phone'
ANDROID VERSION - 2.3.5
HTC SENSE VERSION - 3.5
SOFTWARE NUMBER - Zero Hero Sense 3.5
KERNEL VERSION - 2.6.35.14-Las_Venturas-1.ORC2+riemer@riemer-PC #8
BASEBAND VERSION - 63.18.55.06SH_6.35.17.03
BUILD NUMBER - HTX Zero Hero Sense 3.5
BROWSER VERSION - WebKit/533.1
I tried to run Universal Androot and it failed, here's the text file....
o for root !
Version: Universal Androot - v1.6.2 beta 5
Detected OS version:10
ls -l /system/etc
ls -l /system/bin/reboot
cat /proc/sys/kernel/osrelease
getprop ro.product.model
Error running exec(). Command: [getprop, ro.product.model] Working Directory: null Environment: null
java.lang.ProcessManager.exec(ProcessManager.java:224)
java.lang.Runtime.exec(Runtime.java:189)
java.lang.Runtime.exec(Runtime.java:275)
java.lang.Runtime.exec(Runtime.java:210)
com.corner23.android.universalandroot.utils.Utils.genSysInfoReport(Utils.java:111)
com.corner23.android.universalandroot.UniversalAndroot.go4root(UniversalAndroot.java:188)
com.corner23.android.universalandroot.UniversalAndroot.access$2(UniversalAndroot.java:183)
com.corner23.android.universalandroot.UniversalAndroot$1$1.onClick(UniversalAndroot.java:92)
com.android.internal.app.AlertController$ButtonHandler.handleMessage(AlertController.java:161)
android.os.Handler.dispatchMessage(Handler.java:99)
android.os.Looper.loop(Looper.java:150)
android.app.ActivityThread.main(ActivityThread.java:4389)
java.lang.reflect.Method.invokeNative(Native Method)
java.lang.reflect.Method.invoke(Method.java:507)
com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:849)
com.android.internal.os.ZygoteInit.main(ZygoteInit.java:607)
dalvik.system.NativeStart.main(Native Method)
ls -l /sqlite_stmt_journals
ls -l /data/local/tmp
ls -l /app-cache
run mount
Error running exec(). Command: [mount] Working Directory: null Environment: null
com.corner23.android.universalandroot.utils.Utils.genSysDebugInfoReport(Utils.java:174)
com.corner23.android.universalandroot.UniversalAndroot.go4root(UniversalAndroot.java:189)
I'm away from home this week so can't offer much practical help, I'm afraid. I assume you're unable to boot into recovery and restore a nandroid backup?
