Help Unable to Charge Warning (in car dock)
davvy1856
Member
I've gotten this warning twice now. While I'm playing music in the car, a window pops up telling me that my phone is using more current than the charger is able to deliver. My dock sits over an air vent; could it be too cold?
Anyone else get this?
it means what it says, you are using more power than you are getting while charging.
you should get a Charge only cable that will give you more current to keep up with your phone and apps that are demanding a lot of battery power.
some cables are sync and will only output 500 mA which is USB current. its trickle charge at best.
You should look into a different charge cable and cig lighter setup. go here for suggestions:
http://androidforums.com/htc-evo-4g-lte/578737-any-recommendations-car-charger-evo-4g-lte.html
... My dock sits over an air vent; could it be too cold? ...
Shouldn't be too cold ... unless you'll cool it there below 0C (32F) ;)
The phone will be charged with a battery's temperature of 0C (32F) to 45C (113F).
With temperatures outside of this range the phone's charge controlling will shut down the charging for to protect the Li-Ion battery.
Harry
