Help Unable to edit contacts
Hello'
I just bought my Galaxy Tab 2 10" recently and when I started editing my contacts, I found a problem. Every time when I press "edit contact" the program crashes and it gives me the "unfortunately, Contacts has stopped".
Any ideas ?
Thank you!
A factory reset would more than likely clear this, although you would lose all your data/info.
If your Tab is unrooted, download Kies, and install.
http://www.samsung.com/ie/support/usefulsoftware/KIES/JSP
Once installed, connect your tablet and see if there is an update for ICS available, this may help to resolve the issue that you are experiencing.
You can also check and install updates for the tab over your network, go into settings - about tab and check for updates, however i found this to be extremely unreliable.
