Help unable to host a hotspot without it reseting
I like to host hotspots to play minecraft over it but it always resets before you can do anything on it. So I think this problem should be resolved and also be able to connect to your hotspot through the wifi. And reason would be for letting you see stuff like servers that only the others would usually see, and would let you commuticate through it as well. And those ahving trouble gettIng your hotspot to stay on, turn off wifi locations.
fixed post: mian issue is that there needs to be a wifi hosting option instead of getting an app to do it for you, and fix that crashing to.
