check in your device manager to see if its loading the correct drivers. if not then uninstall drivers from device manager then search for hardware changes and reinstall drivers. btw theres a thread for unbrick questions.
http://androidforums.com/motion-4g-all-things-root/610609-guide-unbrick-unroot-lg-motion-4g-kdz.html this has actually been discussed in the last page or two of that thread.
try a different usb cable
if you have had the phone for less than a year you can also go to the lg site and request a ra (repair authorization )# then send it to them and they will just put a new mobo in it. if they give you an ra# i would go ahead and fry it all the way lol before i sent it. metropcs will just send it to lg anyway except charge you for it. it only cost me like $6 using the small if it fits it ships box at the post office when i sent mine to them. just say it no longer powers on when you fill out the ra request. but you can try metro if you want but i doubt they will replace it since they dont sell those phones anymore.
i should probaly just let it sit in water for a while huh. lol
i wouldn't use water, i would just use that ghetto charger again. but only if your sure metro will replace it
