Help Unable to use better cut!!
namlee78
Member
Seems every time I try to open BetterCut (So I can edit/change my icons) I get the message
"Unable to edit shortcuts for Android Home, if you are editing Open Home, you MUST install Open Home first. The easy solution is just uninstall BetterCut and reinstall it (without uninstalling Open Home).
I don't use open home, and I've tried reinstalling. Any ideas?
