You live up to your name. LOLYou are a god @twogbsd ; fixed my old LG L70 that was bricked with chainfire 3d (derp)
I break more than just phones; but its all in the name of SCIENCE!You live up to your name. LOL
Can't i unbrick from adb instead ?Has anyone else had this problem and managed to fix it ?
Nope one time I bricked my L70 D321 and got the kdz and tot files from the (OUDHS) Official Unloved Device HitSquad but their no longer on thereHas anyone else had this problem and managed to fix it ?
not sure why you guys are having problems it worked fine for me. Could you enter download mode? Won't work if you can't.ive got the same problemSo I did this and now I'm stuck in a bootloop, I'm going to try once more to see if it help. It says ROOTED in red when it finishes. Idk what I did.
Well, I tried to restore from CM11. It all went well until reboot. Now it just bootloops on boot animation. Can anyone help me on this? I'm pretty much stuck here.
EDIT:
OK, I just found out a solution by myself. Thought of sharing if anyone gets into the same trouble:
1) Turn on the phone and connect it to your PC/laptop
2) While phone bootloops, open un command prompt on pc and type, one line at the time:
This will reboot phone in recovery mode.
3) From there, delete data and cache, and reboot
4) You're done!![]()
i had that issue i went and turned on usb debugging from hidden menu plus installed lg drivers and worked like a charmI tried the software on another computer but it still tells me "The phone is dosconnected from PC"
Can anyone please help ? Im willing to pay if someone fixes it and fixes root, bootloader, custom rom etc since i ****ed up last time even though i follow instructions 100 %
If Download Mode works, then this should work. Are you sure the KDZ is valid and you followed everything? (meaning downloaded right)What I have now is my phone turning on, flashing the MetroPCS boot animation, then replaying the boot animation over and over. ADB and Download Mode are working, and all my drivers are properly installed. The phone is not read by the computer. Tried adb reboot bootloader, and it just reboot. Tried all possible versions of adb reboot and practically got the same thing.
