Root Unbrick/Unroot LG Mach
sammyz
LG Whiz Kid
Ok, this phone does not unbrick the same way as most other LG phones will.
You will need:
Drivers installed- https://www.box.com/shared/32c5t7fj2w8xcwr0krjo
LG Mach Firmware: LS860ZV7_08.S7_08.P25010.tot Alternative: http://www.filedropper.com/ls860zv708s708p25010
LG Flash Tool (read the Readme!): https://app.box.com/s/ua760vn52db4ainj92hb
LG Mach DLL for LG Flash Tool: http://tool.xcdn.gdms.lge.com/dn/downloader.dev?fileKey=CT109871648442116484421/
This guide is intended for windows users. There is no way to unbrick this phone unless you are on windows due to the software being used for flashing only made for windows.
  1. Put your LG Mach in download mode:
    While powered off, hold volume up + volume down + power
  2. Connect a trustworthy USB cable
  3. Open up LG Flash Tool
  4. Tick "Select Manual Mode"
  5. The DLL selected is called "LGLS860_20130220_LGFLASHv141.dll", find where you extracted that to
  6. Select Add, choose the tot file you downloaded.
  7. Press ok.
  8. Read instructions here on how to configure the COM Port and flash: LG Flash Tool - Free - no need B2B User/Pass - GSM-Forum
Phones don't fix themselves
Please Donate
You will need:
LG Flash Tool (read the Readme!): https://app.box.com/files/0/f/591368182/1/f_9470373825
LG Mach DLL for LG Flash Tool: [LGFLASHv141]LGLS860_20130220_Download.zip
  7. Press ok.
Can you please repost the link for the dll file? I clicked on the link and got "Object Not Found!"
My Mach is working again!!! Thanks, man!!
Here's the play-by-play:
1. I downloaded the tot file from uploaded.net/f/ibssdg. The file size is 978mb, and, unless you're a premium member of Uploaded.net, it will take anywhere from 2 to 4 hours to download this file. Also, it took 3 attempts to download the entire file. The first try downloaded a 1/3 of the file, the next a little more, bingo on the 3rd attempt.
2. At first, LG Flash Tool failed in about 2 seconds. The second try took maybe 5 minutes, tops, to go from 'wow, this might work', to around 85%.
3. At around 85% the progress bar stalled, but in a few seconds the phone rebooted to an LG screen, then Sprint screen, then Home screen.
4. Then the progress bar went up to 98%, and I got the all-too-familiar "Download Failed" message, apparently because the connection reset itself. Supposedly there were "500s" left to complete the download. Didn't matter cos...
5. The phone was ready for activation. It will take a few minutes for the phone to reach the network, but it's worth a few minutes of anxiety to finally have a working Mach again.
thanks for this - I guess I need to paypal you some $$
or else let me troubleshoot your car issue! (Japanese car specialist)
PS - can you give me a list of apps that commonly cause this soft-bricking on LG Mach, because the way I soft-bricked it was removing what seemed to be useless apps after I rooted the phone - someone said removing crap like google play music etc. would mess it up? - I also removed Sprint ID, Sprint Zone and Google Play Movies and Google Play Magazines and perhaps a couple of others!
by the way, will this phone ever have an unlocked bootloader or custom ROMs?
Do not delete google play videos.
A bypassed bootloader may happen if djrbliss decides to port loki to this phone. The only thing he needs is your aboot partition. If you have no idea how to use adb, I suggest someone that knows how to use it attempts. Is there a dev anywhere at all that has this phone?
can you delete google play books, google play magazines, or google play music?
I know of no dev in the world with this phone, and I have searched pretty hard!
I do use adb a fair amount to transfer files and/or install non-google play store software
I have an extra LG Mach for development use if you have a recommendation on who could utilize it for the greater good! - I am a 5-row qwerty junky or I wouldn't care about these phones!
Also - I need some advice/help:
when I soft-bricked the phone, I lost the 3G flashing for PagePlus, I would like to restore this flashing using same phone number etc. so I can get the use of the rest of this month of my Page Plus prepaid card! (not to mention makes some calls and have a working phone again :rolleyes: ) - right now I get "thank you for calling Verizon Wireless, we will connect you to an external operator to make a call"
the good news is, I do have a legal, registered, bought and paid for, latest version of CDMA Workshop version 3.9.0, how could I get the correct settings for an LG Mach on Page Plus with 3G for Birmingham, AL (Verizon SID 00113) to reflash it it using CDMA Workshop?
Is everything programmed correctly for page plus? Are you on PagePlus's PRL??
Idk of any devs that would be interested in that phone at all..sorry.
maybe it is noob question, but
setting up the phone on PagePlus is what I need the help with, like if you had an LG Mach and you had the latest and greatest CDMA Workshop, and you have a current PagePlus account, I have all the tools, but the CDMA Workshop learning curve is a little steep - I just need to know what are the PagePlus settings are I need to set in CDMA Workshop, if that makes sense, and I need to end up with 3G service, which I had with PagePlus before it bricked - CDMA Workshop has about 5000 different settings!
PS - I am still wondering if it is safe to delete google play books, google play magazines, or google play music?
Yes you can delete all that. There's another guy on pageplus with the LG motion. He can probably help you. I don't have time to find him, I g2g to church.
maybe see if chevanlol360 and mavrikmeercat wants to take a crack at it it would be cool to see if megatron went from samsung to lg but sadly i doubt he would
