Root Unbrick your (almost) fully bricked Fusion 2 U8665 (not for soft bricks)
ZeRoseDev
Let's Unbrick your phone
Update
Use this method instead: Restores 3G and IMEI as well as unbricks any Fusion 2
http://androidforums.com/fusion-2-all-things-root/820340-fix-everything-fresh-start.html
Previous Method
Firstly, this is only a method for those who have a FULL BRICK, meaning your phone wont do anything aside from accessing the purple screen.
**If your phone bootloops or gets stuck at the AT&T logo and/or you can reach the Recovery menu, you are NOT at a full brick, this means you're soft bricked and you just need to do a full wipe and reflash your ROM.
As long as your phone can reach the purple screen by pressing and holding Power + Volume up + Volume down at the same time, we can fix your bricked phone.
If you do this, your 3G is lost forever, there will never be a fix. NEVER. You will still have 2G, and Wi-Fi speeds are unaffected.
People with a fully bricked phone will likely not care about that, but if you want to do this for kicks, you will lose your 3G, and no one can help. (This is why I've been sending this information via PM up to this point)
Okay, now that we've covered that:
I will begin with a quick run down; the Fusion 2 is strikingly similar to the Ascend Y201, so ROMs that work on that phone, work on this phone. The difference, however, is that they have an official firmware update(ICS) from Huawei, where the Fusion 2 does not. This of course is bad news for those of us who mess up our phones. Fortunately, we can use their official firmware to fix our broken phone.
If you decide to proceed, you should know, this will, initially, turn your phone into a Y201, so when you root, you will have to do so with the guides for the Y201, and not Shagerty's root guide. (I will provide the links you need below)
Once you have aquired root, and have CWM installed, you can easily flash any of the ROMs for the fusion 2 again, with no issue.
____________________________________________
Please, be aware, this takes a long time, so you should be plugged in, or at least have a ton of battery. Also, don't freak out if you think its frozen, just let it do its thing. DO NOT REMOVE THE BATTERY! You will be left with a total paperweight.
Here are the links you need:
Download the file from my Copy.com account. (pdf instructions and files inside the unbrick.zip in Englilsh)
- https://copy.com/qACNIqGBBEjE
Tutorial on how to set up ADB
- How To Set Up Android ADB & Fastboot On Windows [Tutorial] | Redmond Pie
Root guide for the Y201- (You will need ADB setup)
- [ROOT][CWM] Huawei Ascend Y201 Pro U8666 - xda-developers
:DCongrats!! Your phone is no longer a paperweight :D
If you're feeling extra happy now that your phone is working again, consider gifting me a coffee with the link below
Want to buy me a coffee? You can do that HERE.
hi dear "ZeRoseDev"
i saw that you solved the hard brick for your own phone.
i have a bricked huawei g510 with just pink screen. no recovery and also no fastboot mode.
for the sake of God is there any solution for me?
no one can repair it.
it had official b190 rom and was rooted without unlocking bootloader.
i tried the same rom and also with the higher build number roms in foced upgrade mod (dload folder) but it doesnt work and eveytime it showed update failed.
please help me.
Sorry for the late reply.
The two phone models are very different, so this message will not work for that phone.
If you still need assistance, send me a private message and I will help you search for a method to fix your phone.
Hopefully you got it fixed.
