Help Undeletable Phantom Widget
pornoheft
Hi guys,
I got this problem with my home screen. I got a blank 4x1 space on my homescreen which WAS YouTube but I can't seem to add anything into it, nor delete it off my homescreen. If I long press that area, it prompts me to add a new widget/folder but whenever I do, it says 'no room on home screen'. Been quite a bother and I have yet to find the solution. Hoping you guys could help me out. I'm going crazy here. :(
Using an Xperia Play if that helps.
Hi i had his problem recently, all you have to do is..... settings- applications- manage applications- all- sony ericsson home- clear data. Wipes all your screens so youll have to replace all your widgets but its the only way round it im afraid. Hope that helps
dudeofrude is indeed correct, this was due to an update to the Youtube application/widget itself but those steps will resolve the problem.
