Undelivered Text Messages
mss12
Member
What's with the default messaging app....sometimes I'll send a text message, then 10 min later the warning sign comes on that it wasnt delivered, but in between that time I dont know if it wasnt delivered or not...on all my other phones when id send a text it would say "message" sent right after...showing it was sent. But now if I turn on notifications I get a text back saying my message was delivered but thats extremely annoying. Any fix?
chompsms doesnt have this problem? My main problem with chomp and handcent is it doesnt always show the time sent for every text i send.
yeah i dont believe it does...
luckily for me i dont care, but once the fix comes through u can go back to the in built one.
Handcent will. You just have to adjust the settings.
I had this issue with the native SMS app. You want to make sure that you clear those out or it will send a bunch of random blank messages.
