Undervolting question
lavellep
Hi All,
I've got my S2 undervolted using the excellent guide here (http://androidforums.com/galaxy-s2-...7-12-dummies-guide-installation-settings.html)
I have a slight issue in that sometimes when I take a photo or come off a call, the screen goes black and then the only thing I can do is take the battery out or restart using the reboot method.
I have a feeling this is the famous sleep of death but I'm not sure as I thought that was more a case of the phone struggling to wake from a deep sleep rather than when it has actually been completing a task.
It happened on my old S2 fairly regularly but I got a new S2 replacement yesterday and I'm getting the same issue. I've tried raising all the values by 50mHz but doesn't seem to make any difference.
I'm running Checkrom v6 with NEAK kernel. Just wondered if anybody else had this problem and if so, how they fixed it?
Thanks a lot
There is a known bug in NEAK that causes the phone to crash during the Camera application. It only happens if you invoke the lock screen when the camera application is active. It has nothing to do with undervolting, and is a bug the developer has been aware of since day one and is unable to fix.
I've not come across this problem when coming off a call however.
