Help Undo Rooting effects
@kr
I am using LG GT540(2.1).
I rooted the phone to get the cyanogen but could not finish it as i could not get my phone into fastboot mode.
And now i am stuck in between
Is there any way to get back to my android 2.1 style.
my fonts and all are changed.
And want to roll back to original 2.1
Please help am in a mess..what should i do...
Please its urgent...
Thanks in advance...
If you used z4root, open it & press 'Unroot'... BTW, you rooted your device but did you flash a fastboot ROM? Try flashing again...
yeah i tried to flash it with Clockworkmod using ROM manager app.
Couldn't just get to the fastboot as needed.
I also installed Busybox.
First you have to flash a Fastboot enabled ROM with KDZ Updater, then put your phone to fastboot mode... After that either use the automatic .exe or do it the manual way or the fastboot flashing software... Maybe you are missing or misdid a step...
  • Like
Reactions: @kr
Is there any way to completely restore to 2.1..
May be then i can start over again the flashing process.
Hey Yeah running cyanogen mod now...
was enjoying using it these days..
Thanx again u helped a lot means a lot...
But have some prblm..
Could nt use phone as a USB Mass Storage Device to transfer files between pc and sd card...
Could u plz help...
Could u plz help...
Uninstall the app Swapper 2 with Titanium Backup or Uninstaller for Root
  • Like
Reactions: @kr
Thanks Man...
It worked..
Again one help...how to install app to sd...
You don't need to do that in 2.3... :D Larger apps will automatically install in SD... Also, you can set location for installing apps in Settings>CyanogenMod Settings>Applications... Also, You can move apps manually: Go to Settings>Applications>Manage Applications>'SD Card' tab & tick the apps you want to move... Note that you CAN'T move system apps...
  • Like
Reactions: @kr
Yeah..whats this v2.0
Shld i go for it???
It's an update... SwiftDroid updated to Android 2.3.4, fixed some bugs & improved battery life... Yap, you should go for it. Note that you need to do a full wipe(From Recovery) before installing & you'll loose your data...
okk...
So done upgrading,..
But the problem is GPS is not showing the my exact current location..
Is there any fix of this???
okk...
Make sure "Use GPS Satellites" in Settings>Location & Security Settings is ticked... Also, you need to be in an open space, out of the building; no roof or sth on top...
