Help unexpected freeze
kafka82
Hi All,
recently updated to V10d. All is fine including battery issues. But It happened twice already that OS just freezes (black screen) not responding to any input. Even trying to switch off doesn work..only solution is remove battery.
I recently installed ADW Launcher and using it. Can this be the problem?
The issue happened after unlocking/awaking it.
Im also using a task killer since one week but never experienced this before.
