Hi All,
I have the international variant of the Samsung Galaxy S3 - GT-I9300. I've just done an upgrade to Android 4.3 and find that I am not consistently get the following message:
unfortunately, samsung keyboard has stopped.
I only have the samsung keyboard installed and this message, appears every 10 to 15 seconds I think - irrespective of whether I'm using an application that requires the keyboard. Its as if the process for the keyboard apps starts and then either gets killed or crashes and then restarts and the cycle repeats itself. Needless to say if I try to access an application that requires the keyboard i.e SMS - the keyboard will not come up.
Not sure if I have anyother issues after the upgrade to 4.3 - but this one is pretty annoying - I can't browse the internet, check my emails or do sms. Can't even search my contacts as all of these require the samsung keyboard - which for some reason is not starting or crashing after the upgrade. It was working fine before, so I'm not so sure its a hardware issue.
I've also cleared the cache and data for the samsung keyboard app and nothing seems to fix it. Was wondering if anyone has faced this issue and whether it was resolved without an factory reset?
Appreciate any help?
Thanks
Thanks
