plasticarmyman
Android Expert
Found this on an Amazon review, i figured you all may want to know about this..
LG system lets you DISABLE OR UNINSTALL BLOATWARE! (use the app 'Application Manager' to UNINSTALL APPS it keeps the apk on its own but not running means no update messages, TO DISABLE go to normal settings and 'Apps' find app open settings of it like you would to uninstall and it will say'Disable')
so here's a step by step
To uninstall:
1. Application Manager
2. Uninstall Apps > uninstall the application there
To Freeze
1. Settings
2. Applications
3. find the app and tap it > Select Disable
this is not from my own experience, this is from someone else's....i Cannot verify that this works or even exists...so maybe this is a stupid post....but i figure some of you will try it and let others know that it works or not
To uninstall:
To Freeze
1. Settings
2. Applications
