Uninstall vz navigator?
RavenTai
My droid broke this weekend, have to have a phone so walked in and got an x2,
Rooted with ginger break shortly after for tether, but even when rooted there are some applications that cannot be uninstalled, the button is greyed out, one big one I want rid of is vz navigator
Is there a way?
I uninstalled it, why? Is Vz navigator of any use? I like the stock android navigator just fine and it is free unlike vz navigator. I did back it up before uninstalling.
You won't be able to accept an update and it might could cause problems flashing things. Thats why it's always best to freeze. Then you can defrost all apps to accept an update or do any modding then re freeze your apps
I freeze the bloat and then "hide" it from my apps list using Launcher Pro's option. Aside form taking up space on the drive, I don't have to think about the bloat.
here's a simple solution...
settings\applications\manage applications click "all" then find maps and vz nav... then click on "clear defaults" on both apps.
