Root Uninstalling Apps Problem
cm832
iHave the cricket hauwei ascend and its rooted and iNeed more memory so when iPress unistall on a app it restarts and iCan never delete it,
How can iFix it and unistall apps?
How did you root the phone? Did you do it following the How-to that is posted here, or another way?
Which apps are you trying to uninstall? The default apps that came with the phone?
Are you using Titanium Backup?
If you are just looking to uninstall apps that you downloaded and you no longer want then get Titanium Back (the free version will do that for you with no problems). If you use a LOT of apps then you might want to consider getting Icarus and there is a thread for it under All Things Root.
iJust pressed root and it did it and im tryin to download titanium but it says idnt have anymore space so how do ifree up memory so ican download it? it dnt let me download no apps cuz idnt have anymore space
Menu Key> Settings> Applications> Manage Applications> "Application" you want to uninstall> Clear cache and uninstall
***even if the original post is a joke, someone will need the info.
