Root Unlock / Relock
los panda
Member
do i want to relock after i have rooted? i remember the it was the last step listed on htvdev, but it wasn't necessarily a direction.
what i am really asking is do i leave it unlocked? pros/cons? etc.?
Personally I would leave it unlocked. Especially if you are s-on. With it locked, you won't be able to issue any fastboot commands which might be necessary at some point when you're in a bind!
Just my $0.02
Just my $0.02
makes sense to me. as long as there's no real reason to relock it, i won't.
no need to relock,it isnt a security issue to leave it unlocked and you may as the moderator stated need to issue some commands at some point.
Just my $0.02
fastboot is still pliable with relock. But there is absolutely no need for relocking the device.
(u did unlock the device via fastboot) :thumbup:
