Unlock without foreign SIM?
lexluthor
Android Expert
I had T-Mobile send me a SIM unlock code for my Vibrant.
The instructions are to insert a foreign SIM and then type in the unlock code.
Is there any menu I could go to to type in the unlock code without having to put in a foreign SIM?
dont have a friend with att?
I'll find someone with an AT&T SIM at some point, but if I could just type it in somehow, it's just easier than borrowing their SIM for a minute.
try this then, idk if it works or not but some Googleing brought me to this
#0111*CODE#
where CODE is your 8 digit unlock code. type that in the dialer
to check if it worked type *#7465625# in the dialer, should say network lock[off]
on xda-developers there is a method to unlock your phone and use any sim card you wont. I suggest you just call tmo directly, they give you a free unlock code. Every time I need an unlock code for any of my phones, I just call them, within 14 days they email you with the code and instructions how to unlock. Usually takes less than 14 days.
#0111*CODE#
Didn't work, but thanks.
And the xda thing requires root, which I really don't want to do on my wife's phone.
I'll just wait until I can get an AT&T SIM from someone.
