Unlock x10
It means you can use any sim card in it. For example if it were locked to Vodafone UK, if you unlocked it, you'd be able to use Orange/O2, etc. And I believe sims from other countries while there. Where as debranding would just remove the Vodafone crap from the phone :p but, still only can use a Vodafone sim card.
Guys if you are stuck I can get unlock codes from sony.
Hi there d_dan can you still get the codes my x10 was on 02 but it is unlocked and i use my three sim, tho im not sure if its factory or sim unlocked, im worried bout updating and it gets locked
any help would be very grateful
An update should not change anything, so it should still be unlocked after.
How well does you 3 sim card work in your xperia, i'm gonna put a 3 sim in mine when i get one... what internet settings and such do you need to enter in?
thanks
thanks
ok, guess i will jus hav to wait for the update now then, seems like its taking forever to come to me ?
Yeah works all good and well on the 3 sime, i had to put the settings in manuelly, i didnt use the ones 3 gave me cos they never worked, had to play round wif um till they worked, if you need the settings bud jus give me a shout and ill send um over to you :D
