zhou qiang
after the flashing it says my sdcard is broken
i changed another sdcard, it did not work either
My phone is stuck at the Cyanogen mod boot animation. I formated the data and all that fun stuff. I tried pulling the battery and stuff but still wont go past it.
I'm working on the front cam in those few minutes of free time I can muster, and you are right in believing that it is a kernel issue (but that hasn't stopped us, the display was a kernel issue that took a while as well). Even if it doesn't get fixed soon, by Saturday I should have an A2 rom that fixes the power-off charger issue, adds a few kernel features, and makes an attempt at getting the wireless charging cover working.
The link has been sent, check it out! This is in ZV7I have a lead on the front camera. Could someone on stock ICS pull the file "/system/build.prop"? There are some non-standard properties in there that the camera libs use. Please note whether you are on ZV7 or ZV8 when posting.
Did a factory erase/wipe and then started from scratch
everything works fine up until after I install the b1 rom - reboots, I can see the LG logo, then black.....
my PC sees it when I plug it in via USB but it's just sitting at black right now
-edit:
going to start from scratch and try reflashing everything
What would be the best way to get you a logcat for my boot problem? I have SDK-Tools and Platform-Tools instaLLED....
[it won't go past the cyanagenmod spinning circle]
you need to flash the gapps.Okay! I'm finally on the ROM, thing is, I've never used cm before and I cant seem to find the play store.
SOOOOO I totally just used the front camera...
4.2 Camera on 4.1 worked perfectly...
EDIT: let me rephrase, after installing the 4.2 camera, the normal camera works
EDIT2: Panorama works, so does video
I installed it but it didn't work, however it made the normal 4.1 app show up and work...
If I remember correctly they were saying the front camera doesn't work in this version but mine definitely does
Hi Anyone knows about adding GSM/WCDMA radio in Lucid?
I saw the Lucid processor Snapdragon MSM8660 support GSM/WCDMA, by adding it. the phone can be used in worldwide.
en.wikipedia.org/wiki/Snapdragon_(system_on_chip)#Snapdragon_S3
