i really tried to understand the adb stuff but im stuck. i did one click root and thought i was all good and installed cwm and its saying i need to root but i thought i already did that. any ideas or help would be awesome. thanks,
Jake
when i try to run cwm is says the following
you must root your phone for rom manager to function. superuser was not found at "/system/bin/su" or /system/xbin/su" use google search on your computer to find instructions on how to root your phone.
ok htc sync was running so i stopped it and redid one click root and also completed step five. when i open amonra it says unable to download recovery manifest file.. please check to see if your phone model is supported.
ok i have to be missing something here. i have the recovery.img and i've tried to flash it twice now, once in hboot via cmd and another time using scotts clean flash to flash recovery.img. now what do i need to do, im utterly confused and a bit frustrated here. thanks..
Jake
Ok I'm an idiot. I'm all good. Is there a program that reboots into recovery for you. I'm used to using cwm. Thanks again for all the help! I was actually good a few posts ago and just didn't realize it! LOL
