for starters,make sure you have mobile data turned on then make sure the cover is on,and your sim is inserted. nothing the unlock does should affect data.
you might also check settings/mobile networks and make sure your network mode is set to cdma/LTE(i think)
a couple other tricks:
-reboot
-toggle data on and off
-toggle airplaine mode on and off
-wait paitently and see if it comes back by itself. its possible there is coincidentally a network prollem in your area.
this is all assuming you are on the stock rom still. if youve flashed something custom,what?
lol i came from the incredible and always did all my rooting stuff without teh back plate so i could pull the battery when needed...didn't realize you needed the back plate to get a signal on the rezound!
