and really unlocked only means you can use it on T-mobile... the 3G frequencies, atleast in the States, are only supported by T-mobile. So you can use it on other GSM networks by popping in your sim but it will be slow b/c you can only use edge.... it's really beyond silly to advertise it as an "unlocked" phone. It is technically but b/c of the crappy way the carriers in the states are setup it's not really unlocked.
they all have their own little monopolies.
simple answer: you can't have it on verizon b/c they use an old standard called CDMA...
Not being able to use 3G data on AT&T when you buy a phone made for T-mobile is not the fault of the carriers, it is the fault of the phone manufacturers. There are radios support all five 3G bands (850, 900, 1700, 1900, and 2100 MHz), but so far the only phone that I know that uses those radios is the Nokia N8. Manufacturers limit the frequencies based on the carrier that will support the phone to save costs.
Also, the reason that Verizon and Sprint are CDMA is because CMDA is better voice call quality than GSM. Until 3G came along, if you wanted good voice quality, you went with a CDMA carrier.
The Nexus S will have access to the AT&T 3G network through the GSM Quad band 850/1900 frequencies.
Connectivity of the Nexus S
- Quad-band GSM: 850, 900, 1800, 1900
dude, stop posting this. its not correct. GSM IS NOT 3G!!!!
