Help Unlocking my g2
Anoop99
anyone know what i can use to unlock this?
is there a free way? or should I buy a code?
Where is a cheap place to get Unlock codes?
Thanks for the help Anoop
i just bought a tmobile G2 i live in canada and need to unlock it, do i need to buy an unlock code, or is there an app on the android market
thanks anoop
i bought a Tmobile G2 too and i live in China, my vendor gave me a unlock code he obtained from Tmobile for unlocking purposes. I assume you can ask the sales rep at the Tmobile where you bought the phone for this unlock code. They most probably will ask you for the IMEI series number of your G2, cause what i understand is each IMEI series number matches an unlock code.
Hope it helps.
