Help Unlocking Wildfire S
Hi Lenocm
Can you tell me where you got your code and how much it was please?
I have just bought a BN Wildfire S locked to Orange off ebay...Although in retrospect I should probably have got one that was already unlocked!!
I can't phone Orange and ask them for a code as their website states it needs to be used on Orange for 3 months first... I want to use it on Talkmobile.
Thanks very much
Elaine
Upvote 0
Hi Lenocm
Thanks very much
Elaine
@Elainer03 : I'd steer away from Talkmobile.
-Tekkno
Upvote 0
HI ALL, I have a Wildfire S (2.3.3) locked to Vodafone in Ireland, I also have the unlock code from FastGSM but I have tried 5 different sims from three different providers but the phone turns on as normal and will even work for a while (hours for one sim) and then shows "No Service", I dont get a screen to enter the unlock code. Does anyone have an idea how to enter the unlock code. I have searched the interwebs and only found two more similar problems. Is an XTC the only way?
Upvote 0
BEST TECH IN 2023
Smartphones
